Montag, 12. April 2010, 16:24
Technische Mitteilungen von Honda bzgl. NSX
TECHNISCHE SERVICE BULLETINS
List of NSX-Related TSBs
TSB Number Section of Car Model Years Affected VINs This Service Bulletin Covers:
TSB_90-009 http://www.nsxprime.com/wiki/TSB_90-009 Transaxle 91-94 Automatic Transmission Warranty Exchange Program
TSB_90-020 http://www.nsxprime.com/wiki/TSB_90-020 Maint. PDI 91 Doors, Trunk Lid, Hood and Rear Window Closing Effort
TSB_90-024 http://www.nsxprime.com/wiki/TSB_90-024 Safety 91 Recall: Airbag Module
TSB_90-026 http://www.nsxprime.com/wiki/TSB_90-026 Interior 91-93 Broken Seat Back Cover Clip
TSB_91-002 http://www.nsxprime.com/wiki/TSB_91-002 Body 91 <=000722 Torn Window Sash Rubber
TSB_91-008 http://www.nsxprime.com/wiki/TSB_91-008 Engine 91 <=003162 Low Oil Pressure Gauge Reading
TSB_91-009 http://www.nsxprime.com/wiki/TSB_91-009 Body 91 <=000647 Longer Spare Tire Bolt
TSB_91-010 http://www.nsxprime.com/wiki/TSB_91-010 Interior 91 <=000562 Split Sun Visor Seam
TSB_91-014 http://www.nsxprime.com/wiki/TSB_91-014 Accessories 91 Cellular Telephone Troubleshooting
TSB_91-016 http://www.nsxprime.com/wiki/TSB_91-016 Climate Control 91 <=001654 Increase in Refrigerant Oil for NSX Air Conditioner
TSB_91-017 http://www.nsxprime.com/wiki/TSB_91-017 Tools All NSX Special Tools
TSB_91-020 http://www.nsxprime.com/wiki/TSB_91-020 Accessories All Transferring Information to a Replacement Telephone
TSB_91-037 http://www.nsxprime.com/wiki/TSB_91-037 Engine All NSX Engine Removal/Installation Procedure
TSB_91-041 http://www.nsxprime.com/wiki/TSB_91-041 Interior 91 Replacement Seat Covers/Cushions
TSB_91-052 http://www.nsxprime.com/wiki/TSB_91-052 Accessories 91-92 Troubleshooting for Optional Keyless Entry System
TSB_92-007 http://www.nsxprime.com/wiki/TSB_92-007 Climate Control 91-92 91 All, 92 <=000697 Blower Motor Unit Only Runs on High
TSB_92-014 http://www.nsxprime.com/wiki/TSB_92-014 Brakes 91-92 Anti-lock Brake System Problem Code 1 / Leaking Solenoid
TSB_92-022 http://www.nsxprime.com/wiki/TSB_92-022 Transaxle 91-92 All Manual Transmission Breather Tube Position
TSB_92-027 http://www.nsxprime.com/wiki/TSB_92-027 Climate Control 93 on R-134a Refrigerant A/C System
TSB_92-030 http://www.nsxprime.com/wiki/TSB_92-030 Cooling 91 <=2406 NSX Cooling System
TSB_92-039 http://www.nsxprime.com/wiki/TSB_92-039 Interior 91-93 Rearview Mirror Reinstallation
TSB_93-004 http://www.nsxprime.com/wiki/TSB_93-004 Accessories 91-93 Popping Noise From the Window Regulator
TSB_93-007 http://www.nsxprime.com/wiki/TSB_93-007 Accessories 91-93 Unlocking the Door Sets Off the Security Alarm
TSB_93-010 http://www.nsxprime.com/wiki/TSB_93-010 Transaxle 91-92 Transmissions #3542-5978 Broken Countershaft Bearing Snap Ring
TSB_93-013 http://www.nsxprime.com/wiki/TSB_93-013 Body 91-93 Upper Windshield Molding Shrinks
TSB_93-015 http://www.nsxprime.com/wiki/TSB_93-015 Body 92-96 Broken Seat Belt Tongue Stopper Button
TSB_94-011 http://www.nsxprime.com/wiki/TSB_94-011 Electrical 91-94 Poor Reception or Interference on the Radio
TSB_94-012 http://www.nsxprime.com/wiki/TSB_94-012 Accessories 91-on Out of Warranty Cellular Telephone Repair
TSB_95-006 http://www.nsxprime.com/wiki/TSB_95-006 Maint. PDI 95 NSX PDI Information
TSB_95-008 http://www.nsxprime.com/wiki/TSB_95-008 Heater/AC 91-92 Converting R-12 A/C Systems to R134a
TSB_95-011 http://www.nsxprime.com/wiki/TSB_95-011 Safety 91 <=001507 Front Seat Belt Buckle Campaign
TSB_95-015 http://www.nsxprime.com/wiki/TSB_95-015 Body 95 <=000781 Creaking From the Removable Roof
TSB_95-018 http://www.nsxprime.com/w/index.php?titl…018&action=edit Accessories All ETM Supplement: NSX Cellular Phone Troubleshooting
TSB_96-054 http://www.nsxprime.com/wiki/TSB_96-054 Body 91-96 Fuel Fill Door Won't Open
TSB_97-005 http://www.nsxprime.com/wiki/TSB_97-005 Electrical 95-96 Radio Interference From Ignition Coil (s)
TSB_97-037 http://www.nsxprime.com/wiki/TSB_97-037 EPS 97 <= 000309 Product Update: Electric Power Steering (can be disabled if moved during start-up diagnostics)
TSB_97-041 http://www.nsxprime.com/wiki/TSB_97-041 Interior 91-97 91-96 All, 97 <=000301 Pop Or Creak From The Armrest
TSB_97-042 http://www.nsxprime.com/wiki/TSB_97-042 Interior 95-97 95-96 All, 97 <=000303 Door Lock Knob Needs Tightening
TSB_97-046 http://www.nsxprime.com/wiki/TSB_97-046 Body 98 1998 Acura Paint Codes
TSB_98-018 http://www.nsxprime.com/wiki/TSB_98-018 Body 95-98 Rear Pillar Creak
TSB_98-026 http://www.nsxprime.com/wiki/TSB_98-026 ECU 98 <= 000239 RPM drops too quickly when throttle released over 5000 RPM.
TSB_98-031 http://www.nsxprime.com/wiki/TSB_98-031 Emissions 95-97 Emissions Warranty Extension
TSB_01-007 http://www.nsxprime.com/wiki/TSB_01-007 ECU 00 2000 #3 - #23 Check Engine Light (MIL) may come on during warm-up if heater is in use
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »hfg« (12. April 2010, 16:26)
